Author Topic: Pendular saw control board problem  (Read 4092 times)
Offline carcanholTopic starter
  • Country: pt
« on: November 09, 2015, 01:59:40 pm »
Hi, a friend gave me this pendular saw and it has a problem in the control board.
The motor is DC.
I used an hp printer transformer at 32V directly at the motor and it ran fine but slow(need more voltage?)
It was too slow to cut wood so i ordered some replacement parts hoping to make it work.
The problem was when you turn it on it runs a bit slow and 5 sec later it goes full throttle but more than it should by factory(400 to 1600RPM).
Now i swapped the components in the pictures and it doesn't run always when pressing the on button and when it runs it goes full throttle again and stops after 2 sec.
Anyone have an idea of what is happening? a friend told me those large ceramic? capacitors break a lot. or it could be the diodes?
thanks for any help.
Re: Pendular saw control board problem
« Reply #1 on: November 09, 2015, 04:24:49 pm »
Change C4, as it likely has self healed itself down to a low value.
Online bookaboo
  • Country: ie
« Reply #2 on: November 09, 2015, 05:22:04 pm »
Have you tested the electrolytics for ESR and value? May as well just change them while your at it.
  • Country: pt
« Reply #3 on: November 09, 2015, 06:31:07 pm »
No good, motor still rotates 1 turn or so and stops after several tries on the power switch.
Thx ;)
  • Country: pt
« Reply #4 on: November 09, 2015, 06:32:49 pm »
A Fluke 79III could be used to test?
Going  to change for some nipons i have.
Thx ;)
  • Country: pt
« Reply #5 on: November 09, 2015, 06:54:25 pm »
Changed the electrolytic caps and is the same symptoms.
  • Country: pt
« Reply #6 on: November 10, 2015, 01:40:57 am »
i have 0.8v on the opamp power pins does that mean some zener is busted a not giving it the voltage needed?
Offline Circlotron
« Reply #7 on: November 10, 2015, 02:05:23 am »
Single sided board that has no plated through holes is liable to have cracked solder joints. Re-solder everything then see what happens.
Online bookaboo
  • Country: ie
« Reply #8 on: November 10, 2015, 09:25:05 am »
That or something's pulling the line down, or the zeners not getting a supply to start with.
Sketch a schematic out, that usually makes it easy.
  • Country: pt
« Reply #9 on: November 10, 2015, 06:28:00 pm »
Done, no change, i'm going to make a schematic, strip all components test them all resolder the clean board and if this is not going to work i kill this bitch.  >:D
  • Country: pt
« Reply #10 on: November 10, 2015, 06:29:42 pm »
Using the diode test on the MM is good to test zeners?
Online bookaboo
  • Country: ie
« Reply #11 on: November 10, 2015, 07:13:44 pm »
Depends how high a forward voltage they can put out, if it's lower than the rated zener voltage you wont get a reading. You could try removing the parts on that supply line then testing the voltages at the resistor and zener that way, or remove the zener and use a suitable resistor and power supply to test.
Removing the components on that line one by one may isolate the problem if you voltage at the zener returns to normal.
« Last Edit: November 10, 2015, 07:17:03 pm by bookaboo »
