My repair kit was a bottle of superglue, a few metres of wirewrap wire ( or Cat5 solid core cable nowdays) and a small screwdriver ( 0.8mm diameter) to make the new land, and then solder the new component into place. Superglue then used to hold down the lifted trace and fix the component leads into the hole. Either that or order a 200k replacement board ( and yes, they were 200k each, I did have to order some, the PSU would have made Dave cry at the price, it cost more than Platinum Rhodium alloy mass for mass) and wait a year. Fibreglass board with 4 layers plus, and I was lucky in that most of the time the IC's I was replacing ( SFC2741PM3 oh so often due to offset drift, but could only used the specified part as they were certified) only went to the bottom of the board, and that there were nearby vias if needed on some. I went and bought myself the most expensive soldering iron tip I ever bought, special ordered from RS, the flatpack soldering tip for a Weller station. Bob saw it and asked if he could borrow it, I replied only if I was attached to it. Saved a lot of damage that tip, could remove a flatpack or the TO100 cans easily with it, and it did not lift the fragile copper off those bloody boards.
