Author Topic: Hunting trail camera HC-300/HC-300M repair / schematic  (Read 5924 times)
Offline jtuTopic starter
  • Country: lv
« on: March 26, 2018, 09:43:54 am »
I've got my hands on Hunting trail camera HC-300/HC-300M. It was stated that camera might have gotten wet.
Yes, there were signs of water inside, but minor. I have fixed the rest, working condition now, except camera does not recognise SIM card.
First, I can't google schematic... Aparently this is a cheap chinese clone, I really wonder why no schematic out there.
Second, any hints on how to debug a SIM? Card works in another device.
Veiksmi,
J?nis
Veiksmi,
Jānis
Offline KhronX
    • Khron's Cave - Electronics Blog
Re: Hunting trail camera HC-300/HC-300M repair / schematic
« Reply #1 on: March 26, 2018, 12:08:36 pm »
Any chance you could attach some reasonably sized photos? For whatever reason, those two are tiiiiiiiny...
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
The following users thanked this post: jtu
  • Country: lv
« Reply #2 on: March 27, 2018, 09:11:31 am »
Thanks for noticing. And sorry, I have not learned how to resize pics for the forum easily yet. My mac offers some options, but I have not found a consistent one. There are web services, but those are slow and inconvenient.
Here you are, nevertheless. I'll add more teardown pics later.
Veiksmi,
Jānis
Offline KhronX
« Reply #3 on: March 28, 2018, 01:05:29 pm »
Yeah, if it has SIM issues, photos of (only) the outside won't help all that much, i'm afraid :)
  • Country: lv
« Reply #4 on: April 01, 2018, 08:59:45 am »
Here is link to the album. You can see main board from both sides, display board, sensors board there.
Veiksmi,
Jānis
« Reply #5 on: April 01, 2018, 03:49:58 pm »
Suspect the card holder but check the traces to it for any signs of data. Hopefully the controller hasn't been damaged.
More IPA cleaning around the card holder ?
  • Country: lv
« Reply #6 on: April 01, 2018, 07:16:00 pm »
SIM card holder was prime suspect. Sorry, I forgot to mention that I re-soldered the holder. Cleaning included.
Ok, googled SIM pinouts, SIM holder pinouts. I was not able to find any SIM holder pinout similar to this case.
I tried to poke it with scope anyway. My findings: there is activity starting couple soconds after turning DUT on, high appears to be 1.8V:
pin 1 = ground
pin 2 = Vcc? gets up first, stays high
pin 3 = ground
pin 4 = I don't know, gets up last, stays high
pin 5 = seem NC
pin 6 = should be clock ~3MHz; it does the clock thing for ~3-4 seconds then goes low
pin 7 = should be data line; does something while clock is on, then stays high
To understand the sequence of the events I did it in pairs also: pin 2 gets up first, then 7, then 6, then 4.
I did SIM holder pic and scope screenshots, see gallery.
I should capture the whole thing probably to understand the ending. But for that I need to do some reading first, I'm not that proficient with scope yet :)
Any feedback appreciated!
« Last Edit: April 01, 2018, 07:27:14 pm by jtu »
Veiksmi,
Jānis
« Reply #7 on: April 01, 2018, 09:12:19 pm »
Nice scope !  :)
Yeah I have no idea of SIM card protocols or pinouts either, but you are getting something on the scope, great.
Thoughts....
Damaged card holder, dry solder joint ?
Try another SIM.
Good work.  :)
Offline eduardsk
  • Country: lv
« Reply #8 on: July 31, 2018, 12:45:52 pm »
Hi guys,
I have a very similar problem with water resistance. But the humidity damaged (it started burning when I reconnected it) the cable that connects battery  to the camera.
Any thoughts where could I get this kind of cable?
