hi,
this TV comes with power ON red LED blinking.
Power board model is 715G7734-P03-005-002H and schematics (also in Service manual!) is different but not su much.
So for reference I worked on 715G7734-P01-005-002H and I find Q9101 defected even if it was no burnt.
Then I checked all others components around it also on SMD side and changed as well IC U9101.
-See reference picture for all tested (OK) and changed (CH) components.
All seems to be fine but TV still doesn't power on and power ON led still blinks.
So I tested voltages on exit connector CN9101 and instead of 12V as written I've:
around 8V without cable on the other board connected that goes down to around 4V if I attach the cable.
There is an other strange thing no matter if power board is connected or no, main capacitor C9801 doesn't discharge and stay at 300V.
I think that primary side is ok then now I'll try to looking some problem on secondary side, any help will be reapply appreciated.
