I'm facing an issue with my Philips Air Fryer XXL, model HD9654/90. Here's a breakdown of the problem:
Startup:
Upon powering on and setting a temperature (e.g., 180°C for 2 minutes), the display immediately shows 5 dashes.
Fan Activity:
The fan begins to spin, suggesting the unit is trying to start the cooking process. However, there's no heat being produced.
Unresponsiveness:
After a short period, the fan stops, and the unit becomes unresponsive. I have to unplug and replug to reset it, but the heating issue persists.
Thermal Fuses:
I've checked them, and they're intact, showing continuity.
Temperature Sensor:
When unplugged, it reads around 150 kOhm and decreases when exposed to a heat gun. But when connected to the PCB, I measure 220 Ohm at the connector, and this value doesn't change significantly with heat application.
Given these observations, especially the unusual behavior of the temperature sensor when connected to the PCB, does anyone have insights or suggestions on potential causes or solutions?
Any advice would be greatly appreciated. Thanks in advance!
