Author Topic: philips car radio  (Read 4788 times)
Offline Arlen Moulton2Topic starter
  • I cause mayhem
philips car radio
« on: June 05, 2015, 06:21:14 pm »
hi dudes! i recently purchased a philips car radio from the late 70s early 80s and it keeps blowing fuses and when i fitted a bigger fuse the light came on but no sound or anything. the model number is unknown but it has the classic twin knob setup and is completley black with no cassette deck. it runs off one ic so i can get the number off that it if it is any help. |O O0 >:D :clap: :rant: :wtf: :popcorn:
Offline tyguy2
Re: philips car radio
« Reply #1 on: June 08, 2015, 12:02:26 am »
If you've already placed it in the car, make sure the PCB is not shorting via any metal below it. Otherwise, you might want to provide the forum with a little more information. Good luck!  :-+
[Sarcastic comment] clever joke [/sarcastic comment]
Bitcoin:
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
Offline Erik NL
« Reply #2 on: June 08, 2015, 09:49:54 pm »
I also have a Philips radio that's build in the same period in my old (1972) Trabant. I also happen to live in "Philipsland"
See on the back (or side) for the sticker with model info (something like 22rn...)
Or google for philips autoradio and find the picture to identify:
http://www.radiomuseum.org/images/radio/philips_radios/22rn351_00_901729.jpg
Parts are getting vintage these days but Philips still can deliver most of them
So, provide the info and maybe I can help
In the meanwhile solder out the audio amplifier and see if the fuse survives...
Once identified, you can request a -free- servicemanual. All manualsare available here but not all of them are digitised yet. Just searc (and request) on:
http://freeservicemanuals.info/en/
You are lucky to have a Philips because these are well-documented!
Have fun!
« Last Edit: June 08, 2015, 10:17:37 pm by Erik NL »
  • I cause mayhem
« Reply #3 on: June 09, 2015, 07:16:19 pm »
Have fun!
they also sound really good
Offline tyguy2
« Reply #4 on: June 09, 2015, 08:05:34 pm »
Have you checked the caps? Make sure they are working.
Bitcoin:
Offline bills
« Reply #5 on: June 09, 2015, 08:09:12 pm »
Could it be positive ground ?
Never argue with idiots. They drag you down to their level and beat you with experience.
Offline Erik NL
« Reply #6 on: June 09, 2015, 09:31:54 pm »
Not likely for a Philips... Blaupunkt had switchable (pos-neg 6/12V) but stopped this in about 1970
Also, the negative ground wouldn't matter as long the radio is not built in the car (I understood it is still on the workbench)
But, never too old to check it, I guess :)
  • I cause mayhem
« Reply #7 on: June 10, 2015, 03:43:17 pm »
boy, itd do something if the caps were bad but this one isnt doing anything other than glowing
  • I cause mayhem
« Reply #8 on: June 10, 2015, 03:44:14 pm »
nope, it has a big negative ground symbol on the top
  • I cause mayhem
« Reply #9 on: June 10, 2015, 03:45:34 pm »
ofcourse it is still on the workbench, what dumass works on a car radio...
... in the car!
