I received a Panasonic Pt-A4000U for repair. The projector is dead. No blown fuse. Visually everything looks okay. I do not have any voltages past the relay which is activated by 15V and the relay switches on the 110V and secondary voltages.
It seem the customer had his electrical outlet wired in reverse. Any ideas as to where I should start?
Thank you.
