Author Topic: Philips CM8833-II video monitor repair  (Read 3013 times)
Offline steve30Topic starter
    • Stephen Coates' Homepage
« on: August 16, 2018, 02:37:23 pm »
I was wondering if someone could advise me regarding some CRT video monitor issues.
My Philips CM8833-II monitor's flyback transformer conked out a few years ago, so I replaced it with a new HR Diemen brand replacement. Fortunately the monitor worked after this replacement.
The monitor seems to have a bit of an issue though. The whole picture dims a bit if you display a bright scene (e.g. a mostly white picture). This is noticeable if you try and display a dim dialog box on top of the bright picture, as the dialog box will become even dimmer still.
This isn't too noticeable, but I'm a bit of a perfectionist. Does anyone know what causes it? I can't remember if the monitor did it with the old flyback transformer or not.
Thanks
steve30.
Offline johnkenyon
Re: Philips CM8833-II video monitor repair
« Reply #1 on: August 16, 2018, 03:28:27 pm »
RGB or composite video input?
Offline RobertPS
« Reply #2 on: August 16, 2018, 04:49:36 pm »
Could be a problem with solder joints. These are getting old!
Check and re-solder.
This link is for a document in dutch with common faults and repair tips:
http://www.bas-ditta.info/doc/Philips%20CM8833-2.pdf
Offline stj
« Reply #3 on: August 16, 2018, 05:55:44 pm »
replace the main capacitor on the B+ rail.
it smooths the 100-ish v line that feeds the lopt and pretty much everything else.
when it starts to fail the usual symptom is when you try to draw more current my for example, displaying a bright white screen, the image with shrink a bit or shake because of volt-drop.
« Reply #4 on: November 25, 2018, 08:28:09 pm »
I eventually got round to looking at this again.
The monitor has a 128V rail. There are two electrolytic caps smoothing this rail. I tested both and they were fine, both in terms of capacitance and ESR.
The rail varies by 0.5V between a completely black screen and a completely white screen. I'm not sure how acceptable this would normally be, but it is enough to cause the picture to change slightly.
« Reply #5 on: November 26, 2018, 01:09:32 pm »
Just wondering, would it be worth trying a bigger capacitor on the 128V rail?
Offline stj
« Reply #6 on: November 26, 2018, 01:38:26 pm »
look up the spec of the original, in this application the ripple current is key.
Offline perieanuo
« Reply #7 on: November 27, 2018, 10:27:12 am »
A little more yes but not much.I woldn't increase more than 50%.remove the old one.and of course readjust the voltage, in theory with flyback disconnected.I was doing this only if I hadn't the original value in 'stock'.
I remember when I was repairing tv's maybe your transformer wasn't correctly adjusted (focus bias and acceleration if I remember well, I was doing it based on eye impression on max luminosity)
Of course dry capacitor can do same trouble but I doubt, you can see if it's diformed on his upper side in most cases.
Regards,pierre
Envoyé de mon iPad en utilisant Tapatalk
« Last Edit: November 27, 2018, 10:29:45 am by perieanuo »
