Hi all
Thanks for your replies
stating the bleeding obvious,but you have cleaned the tape heads?
Yes, I cleaned them again and more crud came out. Maybe one of my tapes is shedding. I let it run all day with various tapes.
stating the obious (2) - maybe the heads are not correctly aligned
and (3) it's not impossible the amplification section is not working as it should (dry caps)
A worn head would be recognizable immediatly (the "stripes" on the head will be deformed or visibly worn out) but that is rarely the case other than due to extremely heavy use.
I'm suspecting (2), I wiggled around and it could be that the cassette holder is deformed. I think it sounds better with the chassis out, but I would like to verify this.
.. it's not impossible the amplification section is not working as it should (dry caps)
Dry capacitors in an audio chain invariably give impaired low frequency response, ie tinny sound, not muffled.
The unit does have a treble control. Does it have any effect?
This is a stereo machine. If only one channel is muffled then most likely an amplifier fault. If both channels muffled, most likely the head azimuth is misadjusted or head is well worn. Azimuth error only affects tapes that have been recorded on a machine with correct azimuth. Do a test recording on this machine and if it plays back non-muffled on this machine, almost certainly azimuth has been twiddled by someone.
It has treble and bass, they both work (I did give the pots a cleaning now). It sounds similar on both channels.
I'll go look for DIN adapters to feed some sound in.
Any tips on doing the azimuth adjustments? I have one of those mp3 adapters, is that ok to feed in a test signal? What else do I need to check the output for correct alignment?
Is it possible the heads are magnetised and need degaussing?
