Author Topic: Philips PM 3065 Oscilloscope repair help  (Read 1519 times)
Offline afsarTopic starter
  • Country: in
« on: June 02, 2018, 08:30:04 pm »
Hello guys,
After a long struggle :-\, I got Philips PM 3065 old CRO to test my circuit but unfortunately, it is not working. I tried to fix it but as a beginner, I could not find it where to start fixing. I had open the case and found power supply was making the whistling sound. As a new one is too costly for me so please help me.
Love@electronics
Offline cheeseit
Re: Philips PM 3065 Oscilloscope repair help
« Reply #1 on: June 02, 2018, 11:50:59 pm »
Check the electrolytic capacitors on the PSU board, some or most are likely bad with high ESR and/or are low capacity.
The following users thanked this post: afsar
Offline Shock
« Reply #2 on: June 05, 2018, 08:46:58 am »
Measure the capacitance and ESR on the secondary filter caps and replace if needed.
Replace the Rifa X2 if it's an original, bound to catch on fire eventually.
