Welcome to the forum.
We have some Philips experts here that should be able to steer you in the right direction.
For additional reading get the Tek troubleshooting pdf in the first post on this board.
Normally the first things are to check ALL rails from the PSU are exactly to spec, in your case you need to ensure they are not sagging as they heat up.
I doubt they are, but it should be eliminated from all question.
PSU ripple can be checked with your meter on AC.
Wise to take notes of any repair or adjustments, before and after.
It will help if you give us an idea of how much gear you have to undertake this repair.
