I've measured all the transistors and diodes on the CRT-board, the V3011 and V3012 are not shorted (resistance is about ~750 and ~1100 ohms between pins) Couldn't find any shorted or non-conductive transistor och diodes (all measures about ~750 ohms) either.
Right now I'm waiting for some equipment and probes to take a better look at the supply voltages, just to clear that out.
Can resistors go bad? Sure it can burn-off, but can it increase/decrease in resistance?
In your first post you mentioned the flux had boiled, wouldn't this just be somebodies messy rework?
Maybe. I'm talking about the brown gue on the ceramic capacitors. Also the mountholes of the TO-92 and TO-18 transistors has the brown gue.
Seeing all the boards being fried more or less, there is also a possibility that this specific scope has run for a long time with blocked vent openings. Otherwise the damage would have been concentrated on just a faulty area/circuit and not all parts
I guess that to. I ran it with the covers on for about 10 minutes and it got really hot on top. I guess this is the result of a full working day with a couple of books stacked on top or something.
It actually doesn't have any vents on top or under.
Thanks for all the tips and suggestions so far!
