Current Status: SLOW (Im having exams at the university)
Channel A trace is still way too high and cant be lowered. Amplitude seems wrong beyond calibration too.
The problem doesnt seem stable. After fiddling inside the scope, the trace is even higher than before. I can see something only when i try to see the CAL signal and set amplitude ratio to 50 mV/div. By lowering the position as much as i can, i can see the bottom part of the square wave. <-This happens because of poor connection of the y pos pot. I reseated the connector and the situation improved. Still, trace too high and amplitude too low.
I'm waiting for another scope to arrive, a Tek 2215, to keep troubleshooting the Philips PM3212. Project is currently on hold.Got the new scope! Love it.
Original postHi!
A recently got my first scope, a Philips 3212. The conditions werent specified by the ebay seller i got it from, there was only written "switches and potentiometers need cleaning".
From milking the front panel i found out:
The B channel works fine, amplitude works fine, focus and intensity controls work and the trace is nice and stable.
OUTDATED
The problem is with channel A. I had a trace on first power up, but some time after it totally disappeared. It appeared a second time after a lot of fruitless troubleshooting and the y position looked like out of cal. I mean, i wasnt able to move the trace down enough: with the y pos control at minimum the trace was still in the upper half of the screen. I tried to display the 1.2Vpp cal signal and the trace amplitude displayed was wrong: 1.1v. Tried with channel B, it works perfectly. After a short period of time, there was no trace on channel A. Again.
PLAYLIST OF ALL VIDEOS I MADE ABOUT THIS OSCILLOSCOPE FAULTS:https://www.youtube.com/playlist?list=PLIgTdpoYMz1MnNDh-Nt9bgHrnhoELMqr6UPDATE 1:
Right after writing this post i turned on the scope and.. BANG! there is a trace. Cant lower it much though. Still, i got it on camera
and i'm uploading a short video of the fault on youtube. Coming soon.UPDATE 2:
-Tried to adjust DC balance trimmer pot, the situation improved a bit. Still way too high though.
Maybe the trimmer pot is faulty. wrong. Trimmer pot values are within tolerances.
UPDATE 3:
After cleaning with lots of contact cleaner, channel B trace is unstable too.
Probably oldway is right about weary contacts. You can tell how clicky-er is the mtb range switch compared to the v/div switches of the channels.
Seems like the faults on both channels have similar effects, but different causes.
Channel B is influenced by the ground coupling. Sometimes, the trace is perfectly fine; After you select ground coupling there is no flat trace, but a distorted, lower in amplitude square wave that goes away with a bit of wiggling of the switch.
Update -> Same thing happens when toggling ac/dc coupling
Channel A is similar, but gnd coupling seems to work fine.
Seems like i've to disassemble the front panel. Again.
UPDATE 4:
Cleaned rotary switches with pencil rubber and lots of patience. The coupling switches made the trace unstable when wiggled. Hopefully, spraying lots of cc in them and pushing the buttons a couple million times did the trick.
UPDATE 5:
Trace on A is unstable again. Probably wear of the contacts. The cc magic has worn off. Hopefully, if the switch is kept centered, the trace is stable. Still a bit dodgy though.
UPDATE 6:
Found the channel A problem: transistor V509. I cant tell what is going on, it seems fine. Swapped it temporary with V511. Roughly adjusted channal A balance. Now channel A is fine.
Other lesser problems- Invert channel B doesnt work properly, some times it works some times it doesnt. From playing with the switch i think its a mechanical problem. Since its a low priority problem, i'll deal with it in another moment. SOLVED, YAY! (the plastic cylinder inside the switch was cracked, i glued it to the pot shaft and reassembled it. In 2 hours. Those flying springs are a pain.)
Update Now the switch x10 mag feels sticky too.. I'll probably have to repair it too
After i replace the reed contact, i'll know if i have to. UPDATE I replaced the reed contact. Took me 4 tries but im satisfied of how i soldered it. Yes, the switch doesnt do anything.. Time to pull out the front panel.. AGAIN..
- The x10 switch for mag on the time base doesnt seems to work. Low priority fault. FAULT LOCALIZED, ITS THE RELAY THAT DOESNT SWITCH. Replacement is coming. In 2 months.
-One illumination bulb has failed. I'll probably look for a replacement or replace both bulbs with LEDs. LED SYSTEM INCOMING! when i have time... Done. Now there are 4 red leds (2 over and two under the crt) that illumi ate the graticule. Sexy.
Some pics of the new illumination system:
http://imgur.com/a/0FYc3
