Hi all
I purchased a Philips PM3350A oscilloscope for £10 about 6 months ago at a local radio fair, it is in good condition and as far as I can tell works okay, although it has not been calibrated for years.
The problem is that it has a really annoying screen flicker/flash which gets worse when the screen intensity is increased, it is best described as a bright lightning type flash, usually on the right hand side of the display, sometimes a localised dot and sometimes the entire trace/screen. I was just wondering if anyone on the forum has had a similar issue with one of these, or can point me in the right direction of where to locate the fault? I'm thinking it may be a power supply issue, possibly caps - the only capacitor I've changed is the safety cap as it was visibly damaged. Is this scope worth fixing, I don't want to spend a lot of time and money on caps if the HT may be breaking down and may ultimately require replacing.
I really like the scope, but being an early hybrid I'm not sure of its long term reliability.
Any help is greatly appreciated.
Waran
