Hi folks,
Since i can't find service manual for this device anywhere,
i kindly ask you for any guidance to try find the problem.
Problem description :
The issue is that there's only signal at the bnc output when the potentiometer is
at the upper limit of the range (200 mark).
In other words :
for each of the multiplier sub-ranges (x0.01 - x1 - x100 - x 10k)
i have output signal only when the pot reaches around the 200 mark,
the rest of the range the output remains KO (no waveform, no ac voltage, no dc voltage)
When the potentiometer sits at the 200 mark, the signals are perfect (2Hz - 200Hz - 20Khz - 2Mhz as per sub-range selected switch)
and all controls responds correctly (freq. offset, dc offset , sweep function, amplitude, attenuation, etc)
Please give me any ideas a what stage or part to look for faults !
thank you in advance for your time !
PS: beautiful picture depicting the problem attached
