I can't find any info about it on the net.
The multimeter turns on and seems to recognize the different ranges when I turn the selector in but I get no readings..
No resistance readings, no voltage reading, no continuity...the only thing that seems to work is the current measurement and only on the unfused 20A terminal..I've tested only up to 1A and the meter seems to track the current.
It's pretty clean inside no dust, corrosion or battery leak of any sort..
Also, the 360mA fuse is replaced with a 3A.
I've already cleaned the pcb tracks of the mode selector.
Where should I start troubleshooting this?
