Author Topic: Philips TV unknown pwm controller in PSU.  (Read 2848 times)
Offline eurgencaTopic starter
  • Country: si
« on: January 08, 2021, 07:44:33 pm »
Hello.
I have philips tv 42pfs4012 chassis kts17.1e la. Found service manual but power supply only has shematic without part list.
So I can't find any info for pwm chip.  |O
Can someone help please.
Thanks, Sebastijan.
  • Country: si
Re: Philips TV unknown pwm controller in PSU.
« Reply #1 on: January 08, 2021, 07:52:29 pm »
If this help.
Offline fzabkar
« Reply #2 on: January 08, 2021, 08:36:33 pm »
I couldn't find the part, but I expect it is made by NXP. The "t" looks like an NXP manufacturing site code.
Something like this:
https://www.nxp.com/docs/en/application-note/AN11588.pdf
« Last Edit: January 08, 2021, 08:50:46 pm by fzabkar »
  • Country: si
« Reply #3 on: January 08, 2021, 08:59:29 pm »
Yeh, pinout is not same.
Strange is that google can't find nothing. I try "qet, qet30r, qet50, 30r50" and completely nothing.
  • Country: si
« Reply #4 on: January 08, 2021, 09:38:45 pm »
Hmm. I realize that this is generic chinese board and not made by philips.
This MS3463S PB801 board share a lot of other manufacturer but all share same manual without part list. What chinese's trying to hide in this PSU?
So far found this, same pinout.
Can someone advise if one of them will do the yob.
https://datasheetspdf.com/pdf-file/824155/LeadtrendTechnology/LD7530/1
https://datasheetspdf.com/pdf-file/1246108/FairchildSemiconductor/SG6848TZ1/1
And one more
https://www.onsemi.com/pub/Collateral/NCP1251-D.PDF
https://datasheetspdf.com/pdf-file/637352/FairchildSemiconductor/SG6859A/1
https://pdf1.alldatasheet.com/datasheet-pdf/view/1221279/LEADTREND/LD7536R.html
« Last Edit: January 08, 2021, 10:04:43 pm by eurgenca »
Online Andy Watson
« Reply #5 on: January 08, 2021, 10:02:59 pm »
This one has the "R" suffix.
http://www.datasheet39.com/PDF/824157/LD5530R-datasheet.html
But otherwise appears very similar to the LD7530.
Offline fzabkar
« Reply #6 on: January 08, 2021, 10:44:00 pm »
See this thread:
http://monitor.espec.ws/section27/printview274444.html
The OP seems to be saying that his MS3463S PCB had a chip marked "5A2R". That's an NCP1251BSN65T1G.
  • Country: si
« Reply #7 on: January 10, 2021, 10:23:34 am »
Hello.
O.k. I found this on aliexpress it seems that is replacement from serie N83Gxx, but guess what?
Completely no data for this chip  :-//
https://www.aliexpress.com/item/4001047685082.html?spm=a2g0s.8937460.0.0.98552e0etk44Qz
It looks like this tv is going to trash.
Online Andy Watson
« Reply #8 on: January 10, 2021, 03:50:49 pm »
Either, it is a direct replacement - in which case the existing datasheets apply, or it is not a direct replacement - in which case it is useless.
Have you tried ebay ? Here is one (there are plenty of others), although I am sure you could do much better if you spent some time searching your local ebay.
https://www.ebay.co.uk/itm/202856505223
If you do not want to purchase via ebay use it as a source of contacts - try searching or contacting the vendors directly.
If you want to substitute note that the LD5530R data sheets hints that the device is based on a UC384x (pin descriptions, pin 2, page 2).
Offline fzabkar
« Reply #9 on: January 10, 2021, 06:32:35 pm »
What is wrong with my suggestion?
  • Country: si
« Reply #10 on: January 10, 2021, 07:11:04 pm »
I can use ncp1251x, but which one.
1. there are 2 frequency 65 and 100 kHz
2. what is the difference with protection, there are latch and autorecovery?
I can use either LD5530R but I presum that I have only one try.
« Last Edit: January 10, 2021, 07:13:34 pm by eurgenca »
Offline fzabkar
« Reply #11 on: January 10, 2021, 08:47:35 pm »
"5A2R" is NCP1251BSN65T1G.
  • Country: si
« Reply #12 on: January 11, 2021, 07:42:13 pm »
Parts ordered. Let's wait some time.
  • Country: si
« Reply #13 on: January 24, 2021, 08:02:38 am »
Well. Parts arrived and PS works fine. I ordered LD5530RGL and for now looks good.
Andy Watson and fzabkar thank's for help. :-+ :-+ :-+
