Hello,
I acquired nice Philips led laps for the workshop, that are powered from philips xitanium power supply (pictures included). While there are many versions of the driver mine are unfortunately not "dimmable" - the only control method is SimpleSet interface. I am wondering if there is an option to add dimming function.
Driver can be set by the simpleset over a wide range, so most of the hardware is there. It is very likely that dimming and other controls are on the small PCB (control.jpg) that is also connected to simleset antenna. Does anybody know this drivers? Or maybe someone has a dimmable version of similar driver and can send me some pictures of the boards? Control PCB has quite a lot of unconnected pins, so it is possible that some of them are used for dimming.
Best regards,
Michael W.
