Hello everyone, I guess I need a bit of an input.
I recently got myself a Philips PM 2525 (my first bench top DMM, will arrive the next few days), and as you do with old tech you go in and check.
Next to greasing the selector wheel gears (motorized selector inside), I also wanna replace the old BR 2/3a 3V Litium battery.
As this battery (most likely) holds the calibration, a simple solder out and in won't do.
So my question to the experienced voltheads:
Would it do to "just" have the system on mains and operating to keep the cal while changing, or will I need to look for points on the board to solder some leads on to hook it up to my bench psu and keep it alive over that while replacing the Bat?
Sorry if this might be a stupid question, I did amplifier recaps, repairs and such stuff, but I never before worked on a cricuit that depended on staying alive while doing so.
