Author Topic: Phillips 32PFL4305/V7 LCD TV Troubleshooting  (Read 704 times)
Offline GassanTopic starter
« on: August 14, 2019, 07:34:54 pm »
I'm stuck with this Phillips 32PFL4305/V7 TV.
I know that both the power supply and the inverter board are working properly.
What I'm not sure about are the main board and the T-CON board.
The main board is not sending any voltage to the T-CON board through the LVDS cable. So my suspect is the main board.
Any suggestions?
Offline keymaster
  • Country: gr
Re: Phillips 32PFL4305/V7 LCD TV Troubleshooting
« Reply #1 on: August 15, 2019, 05:24:02 pm »
service manual
(https://elektrotanya.com/philips_24pfl5505_24pfl4505_32pfl4305_32pfl3305_42pfl3505_chassis_tcl_ms19c_lcd_tv.pdf/download.html#dl)
follow the power rail .
remove to t-con and see what happen to the power rails .
