Q1 provides inversion, so the overall feedback via the R4,R3 potential divider to the +in of the OPAMP is actually negative. As a whole, IC2 and Q1 act as a buffer with a gain of two and an output that can source as much as Q1 can withstand but only sink a fraction of a mA via R6.
Check the output of IC2. If its up near 5V, Q1 has failed shorted. If its down near 0V, either IC2 is bad or R4 has failed open. I'd put my money on Q1 having shorted. On most clones there isn't a lot of copper area to dissipate heat from its drain and its easy to cook it powering a lower voltage target that draws too much Vdd current.
