Author Topic: Pinout EPROM MSM3758  (Read 3265 times)
Offline olliisitTopic starter
« on: May 21, 2015, 01:34:25 pm »
I have an older German made milli ohm gauge.
I wanted to save the Firmware of this device , but the EPROM OKI MSM3758AS (M3758AS) is unknown by my programmer.
Maybe the EPROM is compatible to standard types  - but i could not find a datasheet or Pinout.
Could someone help ?
Offline amyk
Re: Pinout EPROM MSM3758
« Reply #1 on: May 21, 2015, 02:17:37 pm »
When was it made? Youi can try looking at these: http://ftp.df.lth.se/pub/bitsavers.org/pdf/oki/_dataBooks/
...but at least from the '82 and '86 ones it seems a 37xx is RAM, not ROM.
Online wraper
  • Country: lv
« Reply #2 on: May 21, 2015, 02:23:25 pm »
Online wraper
  • Country: lv
« Reply #3 on: May 21, 2015, 02:31:59 pm »
Could be compatible (at least for reading) with 2758 eproms.
Offline wagon
« Reply #4 on: May 24, 2015, 11:52:16 am »
What a ripper resource.  Thank yoU!
Hiding from the missus, she doesn't understand.
« Reply #5 on: May 24, 2015, 12:57:26 pm »
Hello all ,
Sadly the Problem is not solved.
I get my hands on a old Data I/O 288A Programmer which supports 2758 Devices.
I used the old programmer with a really old PC with MS-DOS - but i coud not establish communication with the programmer.
After all i found the solution about the correct Interface cable pinout.
See attachment for a working ! interface cable.
The interface cable which was part of the programmer i got was not working (incorrect pinout).
But even these old programmer cannot read the MSM3758 EPROM.
The ..2758 devices i tried leads to a read error.
i tried several other eproms i have - reads all without problems (& file saving). --> programmer is working correct.
The gauge i have is working --> Original EPROM is intact
Maybe the device have a special Pinout or whatever .
So i am still looking for a original MSM3758 datasheet to narrow down my problem
Offline amyk
« Reply #6 on: May 24, 2015, 01:57:47 pm »
Try asking Oki, or reverse-engineer how it's connected on the original device. If it's connected to a CPU it should be relatively easy to determine the pinout.
