Author Topic: Pinout/Datasheet for 1002DS 16-pin DIP - HP Z800 (Correction)  (Read 1365 times)
Offline Lorenzo_1Topic starter
Corrected - this is a 16-pin DIP of course!
I've been working on and off on a faulty HP Z800 850W computer power supply.  I have one unit with an intermittent fault which starts up OK and one unit that's failed completely in use.  After much comparison of working and non-working units, powered and unpowered, I've traced the fault as far as the pins of a 16-pin DIP on the secondary side marked 1002DS and "9G1 6". Looks to be monitoring 5V supply, which is working OK on both circuits. IC has no obvious manufacturer's mark. I think it might be an STM1002DS, described as for voltage supervision & comparator.  Much searching failed to turn up a datasheet - and some suggestions STM might not have released one.  The part is obsolete but still purchasable.  Can anyone help with a datasheet and/or a pinout/likely pinout for this IC?
Attached are a couple of images showing the relevant parts of the front and back of this board.
« Last Edit: March 13, 2020, 10:24:17 am by Lorenzo_1 »
