Trying to fix an old Xbox 360 Elite that has a dead ICS1893BFLF network chip.
Died due to a lightning. No power adapters where attached though. Only ethernet cable to router.
Everything else seems to work as normal on the Xbox.
So, for me to have something to do i was thinking this might be a little project for me.
Chips can be bought from ebay quite cheap.
Also could be a good time to use my new Quick 957DW hot air station.
Anyone else done this?
Any recommended tools, heat, air flow speed etc?
Obviously i do not have any schematics for the Xbox. But i have at least the data sheet for the ICS1893BFLF chip with block diagrams and pins.
Here is the link for that data sheet:
https://www.renesas.com/us/en/document/dst/1893bfbk-datasheetI have not verified that the only thing that are might broken is the chip. There might be other components too.
But everyone tells me that the chip is dead. And are a common issue when lightning hits the box via ethernet.
