Hey to you all!
I am fed up searching for replacement ribbon LVDS cables for this panel. Is not difficult finding manufacturers making these in bulk, but there is just no way of finding the correct cable... Or they are too short, or have too much pins, or the temperature or voltage ratings are wrong...
The cables I need are Sumitomo-G AWM 20941 105C 90V VW-1-F, 26pin 0.5mm pins... Lengths in 600mm and 850mm... Or ANYTHING similar haha, as long as it fits and does the job
Is there somebody who can point me in the right direction? Does anybody know how to get hold on these?
And another question: Is the "high temperature" rating that important? Or even the Voltage rating? Are weaker cables bond to snap or melt due to high temperatures or too high voltages?
Reason of replacing is because the old ones melted in the TV
Thank you so much in advance!
