Managed to switch the TV on today a few times and power was all good, and then again it would no longer switch on, going back to the 8 Blue LED’s, and no distinct click sound (Relay switch?) that you would normally get when the set is switched on. However I also noticed today that a few times, after removing power supply to panel and re-connecting that it would have two rectangles red and blue moving right and left with blinking alternating red and blue LEDs. Once or twice it ended up in standby by mode with just red LED, but failed to switch on, or it would try, could hear the distinct “Click”, and blue LED but then the media receiver was in Standby mode (Red LED), and panel shutdown again a few seconds later.
As I do not know where the problem is or which board to replace (Power, Audio or Main), it looks like I either need to take it to an authorised repair workshop, which could be costly so may start to look for a new TV, as parts are also now getting harder to get hold off for these sets.
