The reason I off-set the transistors on the bar is because it allows the legs to align to the board with just slight bending. I clipped one emitter leg and swung it over to the other and it will be silver-soldered at that joint.
Does it matter which side of the board the transistors are mounted on?
Here is a transistor being mocked-up.
*Update*I installed the new transistors and plugged the receiver into my home's wall outlet (~122.5 VAC). Here are the "DC Offset" results:
64.9 mV at the Left Channel speaker terminals
62.3 mV at the Right Channel speaker terminals
Voltages at the new transistors:
Right Channel:
B +0.2 VDC
C -29.4
E +0.7
C -28.1
B +0.2
Left Channel:
B +0.2 VDC
C -29.4
E +0.7
C -28.1
B +0.2
They are identical. But, the collectors should measure a little lower in voltage per the schematcs (-26.5 VDC and -25.3 VDC).
So I put the receiver on the Variac and lowered the AC voltage until the voltages at the transistors aligned to the schematics. When the voltages at the transistors aligned to the schematics, the AC voltage at the Variac was at 111.8 VAC output.
But this is the most important part:With the voltages correct at the transistor's collectors (-26.5 VDC and -25.3 VDC), and the Variac at 111.8 VAC, the DC Offset dropped to 33.4 mV for the Right Channel and 35.8 mV on the Left Channel!
Guys, we need to find a way to lower the voltage to the transistors while the Pioneer receiver is plugged into a 122.5 VAC outlet.
...and I make many edits to my posts, so please check them regularly
