Hello EEV community !
I have a problem with my old AVR companion Pioneer VSX-323-K.
it no longer turn on. When I press power button, the power supply board relay clicks then powers off straight (the far right end of the display lights up very briefly then off)
- pressing the power button generates a click caused by the relay on the standby PCB
- a long press on this same power button, turns on the amp, which goes into protection after a few seconds by turning off and flashing the red "HDMI" LED
- by performing a reset (power key + "advanced surround" for more than 3 seconds) we return to the original problem which is that the amp does not turn on.
By disconnecting the processor card (HDMI + DSP) the amp turns on and stays on. But no sound is emitted, even with the tuner. Shorting the relay on the standby PCB card will force the amp to turn on and go into protection (HDMI LED flashing).
this issue is not directly related to the amplifier card. I have checked absolutely everything in the amplifier and power supply. No component is burnt out or weakened.
Do you know where to look? I have no idea.
Thanks !
