If you are reading a voltage that high - you are using the wrong ground reference, or you have a floating ground. WARNING: under some circumstances, this could put that high voltage across a main filter cap, rated at only 71 volts. It could potentially heat up dangerously, and spew it's contents.
I have seen this happen before (not on a Pioneer).
