Author Topic: plasma tv power board repair  (Read 1206 times)
Offline ant17Topic starter
« on: January 15, 2021, 09:44:15 pm »
hi guys i have a faulty smps for a samsung tv the board is a BN44-00516a. But i am having trouble diagnosing the fault originally it a had 3 shorted transistors and a faulty Infineon-ICE3BR2565JF switch mode ic which were all replaced. I also had to run a wire to lifted pad on the switchmode ic and the short was gone and powered it up but still no standby voltages. So the high voltage side seems to about 320vdc and low voltage isolated side no voltages at all.
Without a schematic i feel like i am bashing my head up against a wall my mind doesn't want to give up but where do you draw the line in repair when is something beyond saving? how do you guys get around not having a schematics?
 i am verry interested in peoples oppinions i have heard from other people they reverse engineer the board but thats alot of work and is worth hassle?
Offline KevinA
Re: plasma tv power board repair
« Reply #1 on: January 15, 2021, 10:45:11 pm »
Electrotanya claim they have the schematic, but I have no idea how accurate it is.
Personally, I have never bothered to try and repair these types of boards - 90% of the parts will be pure unobtanium; Shove a reclaimed board in it; it is probably cheaper than sourcing the spare parts.
The following users thanked this post: ant17
Offline ttx450
« Reply #2 on: January 16, 2021, 01:05:41 am »
what is your time worth? :popcorn:
« Reply #3 on: January 16, 2021, 01:32:40 am »
ok guys i appreciatate your honest oppinion so its more of a spare parts source than trying to fix it
« Last Edit: January 16, 2021, 01:39:00 am by ant17 »
Offline sean0118
« Reply #4 on: January 16, 2021, 03:56:25 am »
This might be a similar issue? Which transistors blew up? There's schematics listed in the thread, not sure if they apply to your board or not.
https://badcaps.net/forum/showthread.php?t=51520
« Reply #5 on: January 16, 2021, 08:45:01 am »
ok thank you for your reply
Offline KevinA
« Reply #6 on: January 16, 2021, 07:29:17 pm »
TV repair kits, 107 Drury Ln, San Antonio, TX 78221 do a board repair kit.
The Repair Kit Includes:
Fuses (2) FS801S, FM802S
Transistors (4) QS802, QS804, QP804, QP802
Integrated Circuits (4) IC801, UQ802, US801
Diodes (1) DP802
Capacitors (4) CS825, CX802, CX851, CX857
« Reply #7 on: January 16, 2021, 09:12:22 pm »
ok thanks all you that participated in conversation thank you
