Hi Harry_22.
I would like to ask if a real ground test point is absolutely required?
I searched several locations,Due to the use of new materials, many pipes are currently made of non-metallic materials such as PVC, PPR.... There are also some old pipelines that have been severely corroded. I am not sure whether these pipelines are really connected to the earth.
I plan to test the 8920a again in 12-16 hours.Do you need the TP1, R40, R41, R42, and C24 test point voltages (measured by a digital multimeter)?
Also, I still use a soldering iron to bake C18 capacitors and take videos, right?
