Author Topic: Please help ID Passive  (Read 1958 times)
Offline Rjc987Topic starter
« on: December 11, 2016, 08:38:12 pm »
Hi, so I have a hard drive that got wet and fried - there are no obvious failures, nothing let the smoke out but I was just checking components with a meter and there's a small white ceramic surface mount component the size of a normal resistor -- it has 2 terminals, and had D over the number 6 written on it. The board labels it vr3 and it has 2 small traces leading to it, not connected to the ground plane. When I test resistance, it's completely open circuit. I think that might be my culprit but I have no clue what it is. Any ideas?
Sent from my iPhone using Tapatalk
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
Re: Please help ID Passive
« Reply #1 on: December 11, 2016, 09:18:44 pm »
i would look for a used drive of the exact same type and swap the electronics. that way you might be able to recovet the data on the discs.
We Are The Watt - Resistance Is Futile!
Offline brainwash
    • Hack Correlation
« Reply #2 on: December 14, 2016, 02:17:48 am »
Could be a fuse, those are USUALLY white, but capacitors CAN be white as well. Obviously swapping a cap for a fuse is a bad idea. But if you don't have anything to lose you could connect a multimeter on amps setting to the terminals.
Also check what the other components marked D are. 6 might mean amps. Fuses are usually marked F on the board. Maybe someone designing SMD boards can have a better idea.
Offline KhronX
    • Khron's Cave - Electronics Blog
« Reply #3 on: December 15, 2016, 11:11:41 am »
That component description sounds familiar - some time ago (earlier this year) i tried to find some data on a similar-sounding component on a hard-drive PCB.
My searches led me to some Murata datasheet or catalog page, if memory serves, describing it as some sort of shock sensor.
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
Online wraper
  • Country: lv
« Reply #4 on: December 15, 2016, 11:24:24 am »
Such questions usually are pointless without providing a picture.
Offline KhronX
« Reply #5 on: December 15, 2016, 06:06:00 pm »
Offline lfostano
« Reply #6 on: December 15, 2016, 09:34:11 pm »
My guess is variable resistor, vr usually stands for that but it is only a guess.
