I'm repairing a loop switcher pedal for guitar. It's basically an analog patch bay which selects any combination (or just one at a time, depending on settings) of 6 different audio in/out loops between the guitar and amplifier. It's called a "GigRig Quartermaster 6". It has a dead channel. I diagnosed it down to this IC, shown below, which had a leg nearly (and now fully) broken off. It intermittently worked when I poked at it with a chopstick, after which I noticed it had almost nothing left of the top left leg. Must have been damaged during the initial install?
Best I have figured, it's a differential amplifier used for switching but I'm not really sure. I usually work with bigger and older gear. I found some ICs with "02WY" in the part name, but they are all 8 pin or more. This one is a 6 pin.
I can't find anything on Mouser or Digikey that matches the text on the IC or the text on the board under it. I've tried so far:
02WY
O2WY
Q2WY
02HM
O2HM
It's probably something common and if I was more familiar with these sort of parts I would know just what to do. Each channel on this switcher has one. I'd hate to loose this whole unit over this little part. The Quartermasters are out of stock everywhere and backordered from the manufacturer and mine is second hand, out of warranty.
Any idea what it, or its equivalent, is? It was located at "IC6" on the board. About the size of a half-grain of rice.
This is a bit out of my wheelhouse, but I can do it if I can get a replacement.
Manufacturer's product info
https://www.thegigrig.com/quartermasterThanks for any help!
