Is the crowbar FET still on, should it be?
Yes, this has not changed behaviour. I checked that the control input to this circuit (opamp (b) - ) is still being held at 0V all the time which means the gate is driven by opamp (a) comparator. Q25 MOSFET will be in full conduction (gate ~ 13v) but D-S voltage is 0.0V, so no effect. Judging from the previous behaviour this should sink a bit of current but not enough to trip OCP etc. I've disabled OVP, OCP on the front panel. So, I
think the crowbar circuit is not instrumental in the current behaviour.
The device has so many optos that you can expect feedbacks from practically everywhere.
Means that what ever you do can also affect somewhere else.
Yeah indeed! I guess the general setup is there is a control line from MCU and feedback return to it. When the MCU was crashed it wouldn't respond to the feedback, but now it is. I'm sure there are a number of things that could result in it shutting off the output but it is odd that it doesn't show an error condition. Previous behaviours were error conditions (No +15V, No AC, no GPIO).
Maybe you should once again measure voltages between MCU socket pins and chip pins.
For zero levels use AC area if you can't trust resistances.
Can you go back to that output voltage on situation?
It's probably too far away but then you could check what MCU pins are different.
Both great ideas, thanks. However, I never was able to measure resistance pin-socket because I can't reach a probe through the very tiny gap in PLCC socket. I've been probing the socket (i.e. external circuit). I did remove the MCU and check resistance of its pins to its ground pin, and same for the circuit.
To go back i'd have to try to put kaptan tape over the MCU SCL pin. That is a really good idea for sure. However, the overall behaviour is quite different and I only traced some of the MCU pins.
For now I'm going to try to trace a bit of the M51995 circuit (switching controller). It is hooked up to 3x 2SK2611 MOSFETs. As expected, they have no signal on the gate - should be PWM. If i can find the control lines to this, then I'd know where to poke around for differences in behaviour.
