Author Topic: Is there any other similar chip that can replace MIC5842YN, please help!!  (Read 1211 times)
Offline daisizhouTopic starter
  • Country: cn
MIC5842YN has been discontinued, can anyone tell me to use another type of chip instead of using it?
Preferably a complete replacement, I don't want to modify the circuit
« Last Edit: January 27, 2022, 01:40:52 am by daisizhou »
daisizhou#sina.com #=@
Offline abdulbadii
Re: Please help if there are other types of chips to replace MIC5842YN
« Reply #1 on: January 23, 2022, 05:43:39 am »
https://octopart.com/mic5821yn-microchip-66526228
Similar parts are not intended to be cross-references and may not be drop-in compatible
https://octopart.com/mic5842yn-microchip-66803473#SimilarParts
Online Ian.M
« Reply #2 on: January 23, 2022, 06:15:07 am »
Something odd here!  Microchip list MIC5842 status as 'In Production': https://www.microchip.com/en-us/product/MIC5842
and Microchip Direct have stock of the YN (PDIP) package with dates additional stock is expected: https://www.microchipdirect.com/product/MIC5842YN
  • Country: cn
« Reply #3 on: January 23, 2022, 10:35:04 am »
I don't know why there are so few brand new ones on the market, many of them are refurbished old chips for sale.
Can I use 74HC164+ULN2824A instead of MIC5842YN?
Online retiredfeline
« Reply #4 on: January 23, 2022, 10:42:58 am »
How about the tpic6b595?
  • Country: cn
« Reply #5 on: January 23, 2022, 09:26:33 pm »
The following picture is the schematic diagram, U2 and U3 are MIC5842YN
« Last Edit: January 24, 2022, 12:16:12 am by daisizhou »
Offline fzabkar
« Reply #6 on: January 23, 2022, 09:31:27 pm »
I like the 74HC164 + ULN2824A solution. In fact I have had to make little daughter boards on several occasions to circumvent similar problems.
  • Country: cn
« Reply #7 on: January 24, 2022, 12:03:05 am »
Is 74HC164 + ULN2824A the best solution? Can you check for me? The circuit schematic is here
« Last Edit: January 24, 2022, 12:16:43 am by daisizhou »
Offline fzabkar
« Reply #8 on: January 24, 2022, 12:42:30 am »
I would be careful with the logic levels. These would be determined by the voltages on pins 4 and 5. You may need a CMOS device for this. I can't make out the Vdd voltage, but logic ground seems to be -12V.
  • Country: cn
« Reply #9 on: January 24, 2022, 01:04:49 am »
MIC5842YN (p1, p4, p8, p9) access -12v voltage,p2 access SCK signal,p3 access MOSI signal,p5 (VDD)access -7v voltage,p6 output signal to U3 another MIC5842YN,p7 input CS signal
« Last Edit: January 24, 2022, 01:08:32 am by daisizhou »
Offline fzabkar
« Reply #10 on: January 24, 2022, 01:19:33 am »
So it's 5V TTL logic referenced to -12V. I can't see a problem with that. Should be OK.
  • Country: cn
« Reply #11 on: January 24, 2022, 01:23:15 am »
This is the optocoupler signal
  • Country: cn
« Reply #12 on: January 24, 2022, 01:29:30 am »
You mean 74HC595+ULN2803 is the best solution? I don't understand why the original author used MIC5842YN (80V withstand voltage), but the 50V MIC5841 seems to work normally.
« Last Edit: January 26, 2022, 10:15:46 am by daisizhou »
  • Country: cn
« Reply #13 on: January 26, 2022, 08:13:08 am »
I captured the waveforms of the MIC5842YN pin2 and pin3 clock and data pins.And measured the pin voltage of the chip on the spot.
The preliminary plan is to use 74HC595+ULN2803 to make a small PCB, and design the pin definition to be the same as MIC5842YN, insert it into the original PCB board instead of MIC5842YN.
I hope you can give me some advice, thank you
« Last Edit: January 26, 2022, 10:16:14 am by daisizhou »
  • Country: cn
« Reply #14 on: January 26, 2022, 01:39:26 pm »
I drew a circuit schematic to replace the MIC5842YN, please help me to check if the pin definitions I drew are correct, thanks
Offline voltsandjolts
« Reply #15 on: January 26, 2022, 02:24:38 pm »
The HC595 and ULN2803 are a good option and have good part availability.
For future reference there is also these options:
NPIC6C596 and similar from TI
NPIC6C595
NPIC6C4894
  • Country: cn
« Reply #16 on: January 26, 2022, 10:50:10 pm »
Fault damage is generally a breakdown or short circuit of one or several Darlington tubes in the Darlington array.So I designed separate self-contained components that can be replaced individually if damaged。
I drew the 74HC595 schematic from 10-pin, 11-pin, 12-pin, 13-pin, 14-pin, 15-pin, 16-pin, 17-pin, 18-pin, is the connection correct? I'm afraid my understanding is wrong
