Author Topic: Please help in saving this WORKING power supply  (Read 2495 times)
Offline administr4torTopic starter
« on: December 06, 2022, 11:30:47 pm »
Hello,
I have an old furnace in house and this is its working control module.
How can I collect information/date/readings/measurements from this working module so in case if something happens to this working module  I can cross check from the information noted down and find broken component easily.
Should I take diode mode measurements of all the soldered pins on the GREEN SIDE OF THE board?
Any other ideas?
I am not too good electronics troubleshooting :(
thankyou
« Last Edit: December 06, 2022, 11:33:06 pm by administr4tor »
Offline fzabkar
Re: Please help in saving this WORKING power supply
« Reply #1 on: December 07, 2022, 12:40:56 am »
If it were my device, I would trace the circuit.
The coil would be some kind of custom wound ignition coil. Thyristor THY1 would be the ignition switch.
The IC is made by Hitachi, but I can't find any information about it. I'm thinking it may be a custom uC, possibly 4-bit or 8-bit, but I can't remember if there was anything of this kind way back in 1975 (assuming 7518 is week 18 of 1975). I can't see a crystal, so that makes me think I'm wrong.
I see references to an NEC uPC3605CA, but this turns out to be a 3-terminal regulator. :-?
« Last Edit: December 07, 2022, 12:43:28 am by fzabkar »
The following users thanked this post: administr4tor
Offline james_s
« Reply #2 on: December 07, 2022, 01:06:07 am »
I wouldn't mess with it, if it does fail some day it's probably going to be fairly easy to troubleshoot, usually the issue is bad solder joints, bad capacitors and occasionally a bad relay.
That looks very old though, what kind of furnace is it? Personally if it's more than about 15 years old I'd just replace the whole furnace if it fails. Last year I put a new furnace in my brother's house, the old one was only 70% efficient, the new one is 98% efficient and has a much quieter variable speed blower and modulating burner, it's a vast improvement.
« Reply #3 on: December 07, 2022, 02:29:00 am »
yes, its an old furnance and old house, I dont want to spend too much money for furnace now, I am ok with 70% efficiency until it fails. As cost of new furnace is insane now a days. I have upcoming expenses for roof next year :(
« Reply #4 on: December 07, 2022, 02:29:40 am »
how do I trace the circuit? I dont know how to trace it. can you help me?
Offline Black Phoenix
  • Country: hk
« Reply #5 on: December 07, 2022, 02:50:25 am »
When he says trace the circuit means picking up a pencil and paper and drawing where each component is and to where it connects.
You can follow the connections by reading the traces on the PCB or using a DMM in continuity mode and probe component legs to confirm if they are connected between them or not.
More about it:
https://youtu.be/wkAp5x3Z_gc
Offline GigaJoe
« Reply #6 on: December 07, 2022, 03:09:22 am »
frankly , it useless
at first , chip are basic custom logic to manage furnace, it not a power supply at all ...
it turn exhaust motor, if exist
it manage gas valve on/off
ignite it
using a sensor to verify flame
turn on air motor
and do in opposite sequence if unit shut down
due to chip unavailability , the whole board non reparable at all
everything you can do to find same , or similar board.  you need to know what each pin responsible for and with some luck find a similar
for example: pin "sensor" most likely flame sensor, diff board and sensor may be not compatible.
would be a very cool ka-boom if timing to open gas valve and ignition will shifted by differ board.   But it your house anyway
« Reply #7 on: December 07, 2022, 04:49:19 am »
ignite it
turn on air motor
yes, if chip dies end of story, its getting thrown but how do we know if chip is not dead? Take diode mode measurements of chip legs? so if chip dies we know right away and dont troubleshoot remaining board?
Offline GigaJoe
« Reply #8 on: December 07, 2022, 05:13:26 am »
to know if chip NOT malfunctioned you need a detail description how it work , sequence of signals, then compare with actual work.
at least what you can do with multimeter to make a detail schematic and layer of voltage map, when furnace working , so late you can compare.
Offline james_s
« Reply #9 on: December 07, 2022, 05:20:59 am »
I haven't looked lately but a year ago I paid $2100 retail for a top of the line 60k BTU variable speed modulating furnace, with what natural gas costs these days the payback time is not too bad. Of course if you pay a HVAC company to come out and install it they charge a fortune but it's not all that difficult.
As far as repairing that one if it fails, the electrolytic capacitors are the part I'd most expect to fail, one of them looks like it's gotten pretty hot, I suspect that's a zener diode next to it.
« Last Edit: December 07, 2022, 05:22:51 am by james_s »
Offline J-R
« Reply #10 on: December 07, 2022, 07:45:41 am »
Find the controller part number and buy a spare on ebay?
The following users thanked this post: edavid, administr4tor
« Reply #11 on: December 07, 2022, 03:12:02 pm »
On which pins should I take these readings?
Offline coromonadalix
« Reply #12 on: December 07, 2022, 03:27:08 pm »
First i would say this board heat a lot  seeing all the burned spots on the pcb
I would add  more ventilation  with holes in the casing
Capacitors should be serviced  or checked .... mostly the small ones around the ic
Check the parts solders for cold joints, cracked solders
It will fail sooner or later
The coil seem's to be the igniter IE high voltage pulse outputs ??
And the question about  monitoring this device :
Without a schematic, i would not even try any external device additions or modifications or sensors  ... i would need to probe many spots,  one misshap and you could blow a part or create some problems
Mostly due to ac lines going into it  too...
and finally  your sentence:   I am not too good electronics troubleshooting
Get or find a spare in case of ...
Furnace brand / model, and the pcb green side markings   you have some who may tell the model  ending with 37F  ???
Seems an old Hitachi logo ??
« Last Edit: December 07, 2022, 03:40:39 pm by coromonadalix »
Offline james_s
« Reply #13 on: December 07, 2022, 06:50:58 pm »
Frankly even with experience reverse engineering things I would not attempt to take voltage readings off he IC. All it takes is a slip of the probe tip to short something out and release the magic smoke. You could easily damage the board beyond economical repair by attempting to do this.
Offline GigaJoe
« Reply #14 on: December 07, 2022, 07:56:25 pm »
" slip of the probe "
so true , better use a sharp needle like probes, with isolated ends
Offline fzabkar
« Reply #15 on: December 07, 2022, 09:37:34 pm »
What is the model number of the furnace? I notice that there is a 24VDC input, but both relays are rated for 12V. This seems odd. :-?
« Reply #16 on: December 08, 2022, 04:58:34 am »
« Last Edit: December 08, 2022, 05:03:17 am by administr4tor »
Offline james_s
« Reply #17 on: December 08, 2022, 05:09:30 am »
Oh that's a Lennox Pulse, I haven't seen one of those in years. Those are actually super cool, they're essentially a pulsejet engine, completely different design than any other furnace out there. They're one of the first 90%+ efficiency furnace, IIRC some are prone to cracked combustion chambers and I don't think you can get the leaf valves for them anymore but if it's working you may as well keep it going.
« Reply #18 on: December 08, 2022, 05:14:24 am »
Yes, its has not leaked carbon monoxide yet because of known crack issue, I have put 4 carbon monoxide detectors around it.so I want to save  the board of this furnace as much as i can :)
« Reply #19 on: December 08, 2022, 12:56:09 pm »
Well i gave you some tips,  change the capacitors for a start  with 105 degree ones, sames values for voltages and capacity
Check the solders on the board as i wrote earlier it could have some defects on them, mostly the big parts who heat a lot
Venting the board would help cooling it
Once again without no schematics i would not play in it,  when or if it become defective  you will know fast enough
Try to get a spare part, this one seem old enough to became rare on the electronic side of things
attached document for some wirings and tips
Yes its not what you want to hear BUT  you need something to work on before doing any attempts who could result in a dire situation if you do not have a backup plan
Searched  tons of websites for  the IC, never found it ???  some references for near number match but not the good one,  it could have been a custom part in the past
« Last Edit: December 08, 2022, 12:58:09 pm by coromonadalix »
Offline Jetecnet
« Reply #20 on: December 08, 2022, 01:43:25 pm »
There's one module on Ebay
https://www.ebay.com/itm/285059921681
JC
« Reply #21 on: December 08, 2022, 02:00:17 pm »
you all are AWESOME
« Reply #22 on: December 09, 2022, 07:50:01 am »
Where you the buyer  loll
