Hi guys.
I'm trying to fix a board of a plotter for a friend of mine.
When you connect plotter to the pc nothing happens... (pc should show up new usb device)
So I started with thermal inspection and measuring voltages and I believe I have found faulty diode.
There are a lot of the same H7 diodes on the board. All measure 0.484V with diode test except this one that measures 0.390V.
This diode is between 3.3V and ground and is heating up really bad. It looks like it's conducting to the ground?
At first I thought it's basic SM4007 but after googling "H7 smd diode" I got some zenner diodes as result...
I'm worried that if I try to replace that diode with wrong one I'll do more damage than good.
What do you think guys?
