Author Topic: Please help me identify what this component is and its datasheet.  (Read 2953 times)
Offline wayneboncTopic starter
  • Country: mt
Hello
Does anyone know what this SMD component is and it's datasheet? I've been looking for quite a long time and I can't seem to get hang of it. It looks like a 5 pin SOT package and has "61 Y" inscribed on it. Other than that I do not know. It's commonly used in Chinese equipment as it's not the first time I came across it however I never cared to look into what it actually is. I don't have a donor board so I can't take one off something else. Beneath it exactly is a SIM tray.
Thanks!
Offline Armadillo
Re: Please help me identify what this component is and its datasheet.
« Reply #1 on: May 24, 2017, 05:50:30 pm »
Likely is a LDO linear regulartor 3.25volts
Search for Ricoh RP 102 N datasheet.
« Last Edit: May 24, 2017, 05:56:58 pm by Armadillo »
The following users thanked this post: Samogon
Offline DaJMasta
    • medpants.com
« Reply #2 on: May 24, 2017, 05:56:20 pm »
My search came up with a XC9206A1L6M, a 600kHz step down switching converter.... though I don't see an inductor there, so maybe not.
  • Country: mt
« Reply #3 on: May 24, 2017, 07:29:37 pm »
I pulled one out and took some readings with the cable plugged into a supply. This is what I got. On the bottom that is a charging/sync cable. One pin feeds directly off USB Vcc.
  • Country: mt
« Reply #4 on: May 24, 2017, 07:32:57 pm »
There is only a coil nearby :-\
Offline Fisher77
« Reply #5 on: May 24, 2017, 09:02:54 pm »
I agree with Armadillo.
Here is a link for the data shett that came from, page 29: http://www.mouser.com/ds/2/792/rp102-e-844503.pdf
Offline JFJ
« Reply #6 on: May 24, 2017, 11:47:33 pm »
Looking at the RP102x datasheet, the SOT23-5 package pin-out doesn't appear to match the "61 Y" devices pictured above:
  • Pin 4 is labelled as "No Connection" in the datasheet,  but each of the pictured "61 Y" devices has pin 4 connected to a passive component.
  • Pin 5 is labelled as "Output Pin", but its solder pad is marked as "USB Vcc" in the second picture (the highest output voltage for the RP102x series is only 3.3V, so couldn't be the source for the USB Vcc).
  • Country: mt
« Reply #7 on: May 25, 2017, 12:15:37 am »
JFJ, that is what I said after saying that he was correct. However I assumed that since these PCBs are designed and manufactured in China, someone made a "knock off" of theirs. But this can't be the case. As you already said, Pin 5 is an OUTPUT pin when in fact it should be INPUT (USB Vcc).
