Symptom: Does not turn on with DC from the original adaptor. The LCD display works, as well as setup of clock and alarm etc. with backup batteries installed but won't turn on when pressing the power on button, it gives "E" with the low battery indicator flashing.
I've exhausted all I could find online, webpage or youtube videos but have not found or figured out a solution.
Problems often happens with the DC input jack but it's ok.
Apart from the small boards for DC input/audio output and for battery pack input, there are two main boards. I would assume one is for the radio another is for the microcontroller/user interface. There is a flat cable connecting both, I would assume it's largely one way - from the LCD board to the radio board except perhaps a signal (or power) input from the radio board, to which the DC input jack board is connected, at least for the LCD board to know whether there is power. This is based on the fact that, without connecting the DC adaptor or installing the main battery, connecting the cable from the backup battery to the LCD board will cause the LCD display's to reset (briefly showing all the segments). And with only the backup battery, I can set up the clock and the alarm.
Its user manual can be found here:
https://media.makita.co.nz/_media/user-manuals/B/BMR102-UG.pdfI couldn't find a service manual or its schematics online.
Thanks for any help.
