Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Please help to determine what model diode this is
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Please help to determine what model diode this is (Read 599 times)
daisizhou
Frequent Contributor
Country:
on:
October 22, 2022, 01:36:31 pm »
I found this diode shorted while I was repairing the power supply.but I can't identify this exact model.looks like a fast recovery diode.
If anyone knows this model please let me know, thanks
(BT 5INB1)
Last Edit: October 22, 2022, 01:38:43 pm by daisizhou
Logged
daisizhou#sina.com #=@
tooki
Super Contributor
Country:
Re: Please help to determine what model diode this is
Reply #1 on:
October 22, 2022, 01:57:13 pm »
Littelfuse 18V TVS diode.
The “BT” is the important part. (And the LF logo.) The rest is just the date and lot code. (5 = 2015, 2005, 1995, etc; I = September)
As for which exact model it is, that depends on the physical dimensions of the package. Here are some candidates:
https://m.littelfuse.com/~/media/electronics/datasheets/tvs_diodes/littelfuse_tvs_diode_smbj_datasheet.pdf.pdf
https://m.littelfuse.com/~/media/electronics/datasheets/tvs_diodes/littelfuse_tvs_diode_smbj_hr_datasheet.pdf.pdf
https://m.littelfuse.com/~/media/electronics/datasheets/tvs_diodes/littelfuse_tvs_diode_smaj_datasheet.pdf.pdf
https://m.littelfuse.com/~/media/electronics/datasheets/tvs_diodes/littelfuse_tvs_diode_sma6l_datasheet.pdf.pdf
https://m.littelfuse.com/~/media/electronics/datasheets/tvs_diodes/littelfuse_tvs_diode_smf_datasheet.pdf.pdf
Because of the squareness of it and the lack of cathode band, I suspect it’s the SMBJ.
Since this is a circuit protection device, if you remove the suspected shorted one, the device should work again without it. It just won’t be protected against voltage spikes.
Last Edit: October 22, 2022, 02:07:10 pm by tooki
Logged
daisizhou
Country:
Reply #2 on:
October 22, 2022, 02:25:48 pm »
Thank you for your help
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
