Hello,
I am searching for a replacement of a VISHAY "High Voltage Ultrafast Rectifier" model UHF8JT. (
https://www.mouser.com/datasheet/2/427/88956-339625.pdf)
This one has been discontinued and VISHAY recommends as alternative model VS-ETH0806FP-M3. (
https://www.mouser.com/PCN/Vishay_PCN_DD_006_2018.pdf)
However, the alternate model does not come in ITO-220AC package. As far as I understand, this package has the backside isolated so that you can screw it against a cooler.
Do you know of an available replacement in ITO-220AC? This is for the high voltage part of a Samsung TV power board (see my other thread).
If I only get a replacement in TO-220AC package, what will happen if I screw it to the cooler? Does it make any difference? Isn't pin 1 GND?
Is there a way to isolate it? Could I glue some electrical tape? Wouldn't that invalidate the cooling?
Sorry for these lame questions, but I feel stuck on a simple component...
Regards,
Vitor
