Hi folks,
I have an issue with blown zener-diode, here is the photo (next to the red frame you can see intact diode):
Label says it is
UF00. I've tried to google for SOD-323F package diodes with UF00 text and found only BZX84J-C4V3 or CZRF7V5B-HF (
http://www.s-manuals.com/smd/uf). However I'm not completely sure about exact one.
Intact diode has 3.5V on it when device is powered on. I assume it is related to the USB input, because it is located right next to the USB Type-B port.
Are there any possible replacement options?
Many thanks
