Author Topic: Please help with zener-diode identification  (Read 814 times)
Offline jhdoeTopic starter
  • Country: by
« on: August 20, 2021, 12:29:06 am »
Hi folks,
I have an issue with blown zener-diode, here is the photo (next to the red frame you can see intact diode):
Label says it is UF00. I've tried to google for SOD-323F package diodes with UF00 text and found only BZX84J-C4V3 or CZRF7V5B-HF (http://www.s-manuals.com/smd/uf). However I'm not completely sure about exact one.
Intact diode has 3.5V on it when device is powered on. I assume it is related to the USB input, because it is located right next to the USB Type-B port.
Are there any possible replacement options?
Many thanks
Offline bob91343
Re: Please help with zener-diode identification
« Reply #1 on: August 20, 2021, 04:36:26 am »
It's UF0D.  But casual observation shows that the two diodes are the same and in antiparallel.  So measure the good one and replace the blown with a similar rating.
The following users thanked this post: jhdoe
Offline gamalot
  • Correct my English
    • Youtube
« Reply #2 on: August 20, 2021, 02:39:40 pm »
The following users thanked this post: fzabkar, jhdoe
  • Country: by
« Reply #3 on: August 21, 2021, 12:02:59 am »
Thanks a lot! I was able to find retailer on ebay (https://www.ebay.com/itm/333603716254) and order new parts!
