Author Topic: please identify smd item  (Read 997 times)
Offline momolouTopic starter
  • Country: id
« on: March 16, 2022, 09:25:29 am »
can someone identify what tipe this thing ?
from constant adc 600
Offline tooki
Re: please identify smd item
« Reply #1 on: March 16, 2022, 12:24:40 pm »
471 is a 470 ohm resistor. But there’s another thing (probably another resistor) hanging onto the end of it…
Edit: oops, I didn’t even realize that I’d completely missed the 0 key on my phone when replying!  |O
« Last Edit: March 16, 2022, 03:59:49 pm by tooki »
Offline inse
« Reply #2 on: March 16, 2022, 12:26:59 pm »
471=470 Ohms
Online Ian.M
« Reply #3 on: March 16, 2022, 01:57:46 pm »
471=470 Ohms
Yep.  Its <digit><digit><power of ten multiplier> just like the resistor color code (>=10 ohms), before thru-hole resistors acquired more bands than you can shake a stick at!
Offline abdulbadii
« Reply #4 on: March 16, 2022, 03:12:34 pm »
what thought on the white square ?
SMD's R is so easy rule: the last digit is the exponent power number
so
471
=47 . 101
=470 ohm
2402 = 240 . 102
=24000 ohm
=24K ohm
« Last Edit: March 16, 2022, 03:38:51 pm by abdulbadii »
Offline Hamelec
« Reply #5 on: March 16, 2022, 03:23:33 pm »
easier:
the last digit is the number of Zeros you have to add.
Online Ian.M
« Reply #6 on: March 16, 2022, 03:33:14 pm »
.... unless there's a letter 'R' in the code!
Offline inse
« Reply #7 on: March 16, 2022, 07:05:41 pm »
The white square, probably a resistor flipped over, some botch work.
Unsolder it to find out.
