Electronics => Repair => Topic started by: Kalle on July 04, 2021, 08:07:29 pm
Title: Please tell me what this is
Post by: Kalle on July 04, 2021, 08:07:29 pm
I have this component which I need to replace for obvious reasons. I have googled it but can't find anything useful. So if anyone can point me to a data sheet or something, I would be grateful.
It's used in a speed regulator for a small 24 VDC motor. The motor probably use less than one amp.
My guess is that it is either a voltage regulator or a power transistor of some kind.
Title: Re: Please tell me what this is
Post by: jpanhalt on July 04, 2021, 08:22:03 pm
One-terminal devices are "uncommon."  Can you show the backside?
Post by: Audiorepair on July 04, 2021, 08:25:21 pm
https://www.onsemi.com/pdf/datasheet/mbr735-d.pdf (https://www.onsemi.com/pdf/datasheet/mbr735-d.pdf)
Post by: bob91343 on July 04, 2021, 09:10:47 pm
I would guess 2SB745.
https://pdf1.alldatasheet.com/datasheet-pdf/view/12809/PANASONIC/2SB745.html
Post by: fzabkar on July 04, 2021, 11:01:34 pm
http://www.smdmark.com/en-US/search/code?id=b745 (http://www.smdmark.com/en-US/search/code?id=b745)
