Hi everybody!
After some search for the better bargain, I bought a Racal 1992 having options 04A / OXCO and GPIB.
I have had to repair just a couple of things but, at the time being, it seems ok .
Anyway, there is something I don't understand: looking at instruction manual found on the Web, the AUTO TRIG selections shouldn't have any effects on C channels but only on A or B related inputs.
But when I measure a signal on input C, if I select AUTO TRIG as on then the Gate led turns on in a slowly rate and also the indications on display change less frequently... it's like to add a sort of little integration.
Moreover, it seems that the Gate led turns on at a slow but fixed frequency, regardless of the resolution setup.
Of course, without the AUTO TRIG selection on, the Gate led lamps at a different frequency related to the resolution setup.
The software release shown at turn on is 8572 04.04
OK, it's not a problem on itself , the reading seems fine but it's different than expected behaviour and I don't know what is the meaning of change I see.
Thanks in advance for any explanation about !
