Author Topic: Tek 2236 aberrant trace  (Read 657 times)
Offline dsw8191Topic starter
« on: February 27, 2020, 07:48:24 pm »
I've acquired a Tektronix 2236. It works but there is a distortion in the traces even when the inputs are grounded (see IMG_1095).  The degree of distortion is dependent on Y position - worse when the trace is above mid CRT.  Both channel traces superimpose when moved to the same Y position.  The X position of the distortion is independent of time base setting.
I've searched the forum for a similar problem without success.  Hope someone wiser than I can provide an explanation for this.
Offline pbarton
Re: Tek 2236 aberrant trace
« Reply #1 on: February 27, 2020, 10:19:57 pm »
My vote, CRT is damaged beyond repair, possibly the scope has been dropped.
Good news, the X and Y electronics are fine.
More advice if you scroll half way down this page...
https://www.sphere.bc.ca/test/tek-parts/tek-info.html
and another one...
https://www.eevblog.com/forum/repair/tek-2211-crt-weirdness/
« Last Edit: February 28, 2020, 09:54:15 am by pbarton »
