So I have been spending days figuring out the missing enable Signal and I found out that the NCP81174 IC on the backside of the card for Vcore is lacking output voltage for the Driver/MOSFET's.
Also there is no VIN voltage at the RT9059 Dropout regulator. The VIN pin goes to Vmem Inductors, so it is using the voltage of the Vmem rail to to run which is missing due to the missing enable signal at RT8811C PWM Controller.
Voltage on the Vcore is present but extremely low (~200 mV)
There is no short on Vmem, I got that wrong.
Is the RT8811C depending on the Vcore rail (NCP81174)?
If yes, does the NCP81174 rather sound to be completely dead and needs to be replaced is it still possible for a resistor to be broken? If a resistor with no value written on it is broken, I won't find out if its broken.
Does anyone have an Idea where the enable signals comes from? It's currently pulled to ground through a dual transistor (SOT 23 - EN Goes into pin 6 and is getting shorted through pin 1 when system powers on). It'll need a signal on PIN 5 to be pulled high.
Maybe its just a dead GPU?
