Author Topic: Polar T3000 CRT Trace is very dim, even at maximum intensity. Help  (Read 229 times)
Offline aqibi2000
I have a Polar T3000 which has a very faint trace on the CRT.
I would like to have some support to adjust the trimmers to the appropriate levels.
The unit uses the same tube as the T2000/2500/4000/6000
Will take pictures soon when someone chimes in.
Thank you
Tinkerer’
Offline aqibi2000
Re: Polar T3000 CRT Trace is very dim, even at maximum intensity. Help
« Reply #1 on: December 11, 2019, 03:04:13 pm »
888070-0
Images attached. Blue potentiometer R105 is the Focus adjustment.
There is a 1500V line from the voltage doubler circuit in the corner on a separate riser board (large caps and diodes) which I cannot measure since my equipment is only suitable for up to  1kV.
« Last Edit: December 11, 2019, 03:07:29 pm by aqibi2000 »
Tinkerer’
