It depends on how deep your scratches are. I had to do my AN8008 which got a deep, large chemical fog. I was able to remove the lens, then used several grades of sandpaper starting with 600. Yes, this gets out the deep scratches, and makes the lens totally opaque, so then I used something like 1200, then 3000. Finally, I bought the Novus 3-pack of # 1, 2 and 3 plastic polishes. You work a while with the most aggressive paste, then the medium paste, and finally the final polishing liquid. It worked well, took a lot of time, and probably wasn't really worth it for a $20 meter, but it was educational.
